You might as well get two, then if one breaks you can always Bora Da other one.
Brilliant thread, in tears laughing! ๐
If it doesn't inflate, check that you aberaeron.
It can easily happen if you're Ruthin about.
Get it lined up straight though. Sometimes it can just be the angle, see?
Denbeigh certain that it's all done up tight.
Go by Cardiff it leaks.
rim covertor is quite a rarebit* isn't it ? Highly desirable though
(*yes, I'm sure we have but INRAT again)
Or Cadair Idris isn't good enough.
OP, aberdare I ask how you got on? Was the idea a gower?
If you Hafen yet fixed it Cwm Rhonda my place and I'll help you fix it, us welsh pool our resources. I Gwent to the LBS this morning after Brechfa. They had Bettws New-Ports which should Resolven your problem. They were expensive but look robust, should last for Ebbw. Vale for money in my opinion. Happy place my LBS, always lots of Merthyr.
As an aside in discussions about Wales should we refer to LLLLLLLLBSs?
Dont use an adapter in a bigger hole without Ruthin it up first, or you'll make a Pyg of it.
