Spent most of this mornings ride at Swinley trying to work out if there's any difference riding with or without pro pedal. I can't feel any difference between the two settings.
Sag is set correctly as is the pressure and rebound rates. The rubber O ring shows I'm getting about 95% full travel. I've switched between setting 1 and 3 with pp on and no difference. Haven't had it serviced in two years and am think of getting it TF tuned/serviced.
It's not spoiling my ride or holding me back, it's just bugging me.
What do other owners have their's set to?
Never ever use it.
Nomad and Blur don't really need it,they climb and ride great without it.
i dont use it, it makes the shock feel harsh, dead, -so it works bot not the way i like it..., i only used it once for a 2 hour climb, because it sort of "locked" the shock.
find the fox video, give it a overhaul, and while your at it, dissamble all the frame bearings, flush, clean give them some heavy grease, you will be amazed how quick, and subble your rear suspension will be again.
Got a Blur Classic never switch it off, although I do flick the switch on my Heckler.
LOL at the almighty SC using a pro pedal shock on VPP bikes for years...IT MAKES NO SENSE.
Moreover...IT MAKES NO DIFFERENCE!
always off on my Blur
