Can those of you with Santa Cruz Blur LT and LTc please tell me your RP23 shock tune i.e.
Rebound (light, medium or high)
Velocity / compression (light, medium or high)
Boost valve pressure (175, 250.....)
Extra volume sleeve size (eg XV)
These values are all from your shock stickers.
I have an LTc and I am not happy with the performance of the shock. I've been informed that it's not the correct tune.
How are you not happy with the performance?
The BLT has always been a bit weird, they tend to use the XV can, but for 'larger' riders is pants.
Slap a volume reducer in there! That'll sort it.
speak to an expert not this lot ๐
LOCO/TF/MOJO/Jungle The SC spec is apparently tuned to the bike, was yours aftermarket?
Yeah, MOJO are great. They told me to use a volume reducer kit in a DHX Air 5.0 and to turn the rebound damper 3 clicks from full on to use more mid-stroke compression, WTF?
Blur LT here....
Boost Valve Tune 150
Velocity Tune Medium
Rebound Tune Light
XV Air Sleeve
Mine's stock although I did have the Kashima upgrade at the last service and it's always suited me although I tend to just get on with riding and not worry too much..... ๐
I can check my LTc when I get home later if needed?
Thanks CaptainCrash
Yes Wrecker, if you find out that would be great.
Rebound tune; XL
Velocity tune; L
Boost valve; 175
High volume can
Feels perfect to me at 14st. At no time have I considered replacing it.
