same spacer for Shi...
[Closed] same spacer for Shimano and XD freehubs on Hope Pro2 EVO?
I'm going to swap from a Shimano freehub to an XD - does it use the same driveside spacer/end cap?
(I'm on 142x12)
Posted : 14/02/2016 7:26 pm
I changed mine from xd back to shimano and used the same end caps no problem (Note mine is standard QR mind) won't have thought that would make any difference?
Posted : 14/02/2016 7:38 pm
ta.
I'd be surprised if they had different versions but I thought I'd check
Posted : 14/02/2016 7:41 pm
It may not fit. I recently swapped over a XD/QR freehub with a Normal/Bolt in setup and the bolt in endcap was a larger diameter so I had to turn it down slightly.
Posted : 14/02/2016 7:45 pm
The XD - x12 end cap is slightly smaller diameter, if you install with the XD driver with the standard X12 end cap then it will bind slightly - Hope have different part numbers for them
Posted : 15/02/2016 1:15 pm
I believe it should be bundled with the freehub, at least it was in my case (135x10 TA).
l.e.: for instance http://www.wiggle.co.uk/hope-sram-xd-11-speed-cassette-freehub-body/
If you already have the freehub from somewhere else you'll need the XD specific spacer, as mentioned above.
Posted : 15/02/2016 1:17 pm
thanks
Posted : 16/02/2016 10:32 am
