Salt and grit
[Closed] Salt and grit
The snow is meting here this week so I might take a chance with a commute into work on the bike. Are there any sprays or other concoctions that help ward off the salt and grit that have been sprayed on the road?
Posted : 15/01/2009 12:01 pm
Bit of GT85 on frame, forks, brake blocks & rims should help.
Best option is washing properly, no real short cuts unfortunatly.
Posted : 15/01/2009 12:05 pm
[i]GT85 on ...... brake blocks & rims should help.[/i]
help what, you to die horribly?
Posted : 15/01/2009 12:13 pm
good wash afterwards and not too much lube on the chain (it only seems to collect the grit anyway on my road bike).
Good someone noticed the obvious mistake ๐Ÿ˜†
Posted : 15/01/2009 12:15 pm
I use finish line polish on the frame and rims, wouldn't recommend putting it on the rims if you're running rim brakes though.
Apparently it sticks to bikes/cars as they now use a mix with molasses to stop it being washed off the road.
Posted : 15/01/2009 12:27 pm
Lick it clean??
Posted : 15/01/2009 1:20 pm
