Saint Rear Mech for...
[Closed] Saint Rear Mech for XC...
...any reason not to?
Posted : 29/08/2011 6:39 pm
Any reason to?
Posted : 29/08/2011 6:43 pm
If you've already got it going spare and aren't bothered about it being overbuild (weight) for the job it'll be doing, then go ahead and use it.
If you're buying specifically for a build, either save money by going for Deore, or weight by going for XT.
Posted : 29/08/2011 6:46 pm
I need a new mech.
I like short cages.
Cheaper than XTR.
Might be more durable.
Posted : 29/08/2011 6:51 pm
I need a new mech hanger.
FIFY
Is the mech also broken, hard to see in the photo?
Posted : 29/08/2011 6:56 pm
Short cage XT then?
Whatever did that to your XTR one, would probably still do the same to a saint. But a saint will still do the job, they do work well for close ratios as well.
Posted : 29/08/2011 6:57 pm
Mech not broken but pivots baggy and twisted.
Posted : 29/08/2011 7:02 pm
Saints only about 40g heavier then xt, I run saint on all my nine speed bikes. They are stronger and more importantly the spring is stronger in the mech meaning a more positive shift. Great mech. If your 10spd then you will have to go for either the new 'clutch' xtr or whatever it's called, or if that is too much money go for slx
Posted : 29/08/2011 7:32 pm
 OCB
I had one on my road bike, and loved it, it's beautifully made, and will run a big range for the cage length.
I say 'had' ... I ended up swapping it out for an XT M770 purely because the spring was too much for the bar-end shifters to hold on friction (9spd shifters, 8spd block) and it'd happily ghost shift [i]down[/i] the block on long grinding climbs ... which was always an unwelcome surprise.
'Tis safely cleaned up and back in it's box now awaiting reuse somewhere else. ๐Ÿ˜€
Posted : 29/08/2011 7:59 pm
