Sag in my joplin
[Closed] Sag in my joplin
Hi,
My fairly new joplin 4 (just over a month old) sags about 10mm when at full extension, it doesn't bother me hugely as I tend to sit down all the time when riding up and the post is down when pointing the bike downhill. But obviously the post shouldn't be doing this and would like to get it sorted.
So I know you can service the post, I haven't done this yet. So is this what is needed or is here more to it?
Posted : 23/09/2011 5:19 pm
Have a read, probably need to add more oil TBH
Crankbrothers Joplin Oil Change
*For just setting air charge - see below instructions
Holding in remote lever or hand actuated lever, cycle post upside down several times. Let go of lever.
Remove 10mm nut at bottom and unscrew Crankbrothers engraved collar.
Remove outer tube. (Slides off)
Remove micro Schrader valve cap at bottom of compression shaft (flat head screw driver).
Cover Schrader valve with paper towel and release any pressure still in post.
Remove Schrader valve core.
With post right side up, aiming bottom valve into an oil bucket, release remote lever or squeeze hand lever.
*This will release any pressure left and oil.
Holding release lever in, cycle compression shaft (gold color bottom shaft) up and down, allowing oil to drip into oil bucket.
*This will cycle out all the left over oil inside.
At this point there should be no pressure and virtually no oil left in the post.
Refilling post:
Remove seat clamps from post and clamp head into smooth jaw vice, with compression shaft facing up, for easy filling.
With a 60CC volume or more syringe (you can use smaller and just fill it several times) fill syringe to 55cc of 5wt or 10wt oil.
*Oil weight does not matter but the volume does.
Put plastic syringe tip into Schrader hole, slightly screwing it in to create a seal.
Push oil into post at the same time releasing post lever.
Cycle the compression shaft at the same time.
*Your doing a couple of things at once here!
The lever needs to be opened up, as well as being cycled, to allow oil into the lower chamber past the valve system and accept all 55cc of oil.
Put a paper towel around bottom of syringe and Schrader valve to keep oil from “spitting” when pressure is release by removing syringe tip.
*As you inject oil you build a small amount of air pressure.
After all 55cc of oil is into post, install Schrader core (light torque).
With standard shock pump pressurize to 70psi.
Hit release lever, pump pressure will drop, pump back to 70psi and hit release lever.
Continue to do this till it stays at 70psi when release lever is pushed. Remove pump.
Reinstall micro cap, reverse installation of outer tube.
*removal of outer tube in post instruction manual included with post.
Cycle post several times with lever squeezed to activate valve system. Check for firmness at top and holding at bottom.
If it continues to be squishy at top, more oil is needed, only 2 - 3CC max more is needed.
Get post situated back into vice.
Hold lever and cycle compression shaft 5+ times with release lever squeezed. This will be tough as you are pushing against high pressure.
Undo micro Schrader valve cap, cover valve with paper towel and release pressure.
Safety glasses on!
DO NOT SQUEEZE LEVER FROM THIS POINT ON.
Oil will shoot up if you do!
Add 2 - 3CC of oil to Schrader hole. (Schrader core removed)
Close up system, follow above procedure for this.
This will do it!
Go ride!
Setting air pressure in Crankbrothers Joplin seat post:
Holding in remote lever or hand actuated lever, cycle post upside down 5 -6 times. Let go of lever.
Remove outer tube. (Slide off)
Remover micro Schrader valve cap at bottom of compression shaft (flat head screw driver).
Cover Schrader valve with paper towel, Face Upwards, push Schrader valve to release any pressure still in post.
With standard bicycle shock pump, pressurize Schrader valve to 70psi.
Max pressure = 75Ppsi.
Leave pump on post.
Hit release lever, pump pressure will drop.
Pump back to 70psi and hit release lever.
Remove pump.
Reinstall micro Schrader cap.
Grease glide rings and guide block & install outer tube
Tighten 10mm nut at bottom to 40in/lb
Tighten Maverick seal head collar, hand tighten, over tightening this will slow the post down by crushing to rubber seal.
Posted : 23/09/2011 5:21 pm
Had the same problem
Sent it back on warranty.
2Pure sorted it out FOC
Posted : 23/09/2011 10:16 pm
Tbh that all sounds a bit too longwinded, you might just have a bit of an air lock or whatever. My Joplin gets a bit of a bounce on everynow and then. Have you tried just unscrewing the collar and cycling the post up and down several times then doing the collar back up, usually works for me.
Posted : 23/09/2011 10:30 pm
not enough oil as said above in a new post this must be a leak /dodgy seal.
As it is under warranty get it sorted as it will only get worse and never be right
I have serviced a few in the past
Posted : 23/09/2011 10:39 pm
mine did this and a few peeps on here also
when i spoke to 2pure they had a problem with the tiny seal on the pin at the top of the post that operates the post once replaced no more problems
still they blamed me for lack of maintaining it? think they just have a standard letter sorry for the failure but its your fault
Posted : 24/09/2011 7:25 am
Cheers guys, once i get a chance to have a look at my bike again (it is 4 hrs away) 🙁 i will get it looked at, have a wee play with it and if no luck will speak to either The Bike Chain where I got it from or get in touch with 2pure direct.
Posted : 24/09/2011 4:33 pm
Joplins are very straight forward to service but you need to put exactly the right amount of oil in. For a Joplin 4 this is 68ml (I think the 55ml mentioned above is for a Joplin 3). I think I put slightly too much in mine as I don't get the sag problem but can't quite get the last few mm of travel at the bottom.
If you do try and do it yourself, don't do what I did and try to add a bit more oil without getting all the air out properly first. 68ml is a LOT when it's splattered all over your kitchen ceiling.
Posted : 24/09/2011 6:03 pm
I have had 2 Joplins and tbh wouldn't have another!
Posted : 24/09/2011 7:48 pm
 ojom
Hey H28 - it's our problem to sort out, sorry it's not working right.
Swing it in and we will get it dealt with asap.
Do you need a loaner in the meantime?
Posted : 24/09/2011 7:51 pm
Cheers tbc, it's up in the highlands ATM and I am in edinburgh. I will pick it up when I head up in 3 weeks or so and then take it in. So there will be no need for a loaner.
Cheers again
Posted : 24/09/2011 8:18 pm
