Running Pauls Chain...
[Closed] Running Pauls Chain Keeper with Middleburn cranks????
I have a set of sq taper Middleburn RS7s with a 4-arm XC spider and I am thinking about getting a Pauls Components Chain Keeper so I can run the bike 1x9. I am sure i've read somewhere that people have had problems running the Pauls with a Middleburn and had to 'modify' the design somehow.
Is anyone running this combo and if so did you have any troubles when setting it up at all?
The frame as a 73mm BB shell and as its a sq taper bb I have no spacers so can't run something like the mrp 1.x or Superstar XCR so feel the Pauls is the way to go.
Posted : 05/01/2011 12:08 pm
I would have thought it would be fine, you should be able to adjust it to clear the spider. You could always run a Uno or Duo ring for a cleaner look.
Posted : 05/01/2011 12:21 pm
using that ring does look cleaner but I thought someone had had the spider catching on the chain keeper but were able to adapt it somehow to work. I guess I could always try raising the keeper a bit to see if it runs ok. might risk losing the chain if its too high tho.
Posted : 05/01/2011 1:28 pm
Has no one else used this combination with the XC spider?
Posted : 05/01/2011 5:34 pm
Could it have been me you were thinking of? I had chainline trouble with an e.13 XCX and middleburn RS7s and posted a thread moaning about it. The chainkeeper was suggested as the solution to my problems. Obviously the real solution was that I 'needed' a new chainset ๐Ÿ˜€
Surely if the spider was catching you'd just mount the chainkeeper a little higher, or have I missed something about how they work (I've never seen one in the flesh)?
Posted : 05/01/2011 6:14 pm
it may have been that I was thinking about.
if the chain keeper is raised up then it surely wouldnt keep the chain on as securely? thats my worry.
Posted : 05/01/2011 6:43 pm
