Running Hope Minis ...
[Closed] Running Hope Minis on a Nomad - can it be done?
Building a Nomad with bits from old bike but only have Hope Minis. Was going to use on the Nomad but increase rotor size until I can afford some bigger brakes. Using for trail use plus intending to go to the Alps.
So am I mad to try this? Should I also get the pistons changed to avoid dreaded brake fade?
Posted : 16/07/2009 12:58 pm
They will be fine, much better than dragging your feet... ๐Ÿ™‚
Posted : 16/07/2009 1:26 pm
I had Minis on my RFX initially. Fine for UK riding, but utter rubbish in the Alps. Got Saints now.
Posted : 16/07/2009 2:09 pm
i had 180/ 160 hope minis on my kona bear, not light build
with the phenolic pistons they were outsanding
did experience some fade before i put the new pistons in but only in the alps!
Posted : 16/07/2009 2:10 pm
Not so long back you'd have used rim brakes without worry
You'll just - intuitively - adjust your riding to suit what braking power you have
Posted : 16/07/2009 2:16 pm
