RS Yari travel
[Closed] RS Yari travel
Hi, anybody know if I can change my Yari to 150mm travel?
I bought them as 140mm travel, and the stanchions are marked for 140 and 130. If I get the appropriate air spring, will it work?
Cheers.....
Posted : 04/04/2018 12:39 pm
https://www.sram.com/service/rockshox/717
A definitive answer will be in there, you need to see if the parts are interchangeable between the travel or not
Posted : 04/04/2018 12:44 pm
 geex
Yes. You need to buy and fit the appropriate air shaft to change the travel.
RS have just updated (and improved) the design of the air spring for 2019 for the Yari and Lyrik (same chassis).
The new parts should be available to buy aftermarket fairly soon (if not already). There's a good chance these new parts will fit older YARIs and Lyriks too so it might be worth holding on until they are available.
Posted : 04/04/2018 1:49 pm
