Anyone know if the all travel 426 Revs are supplied in 125 or 140mm setting?
I can measure about 145mm of exposed stansion but seem to only get 125mm travel. How easy is it to change the travel if I need to?
Posted : 10/05/2009 1:52 pm
They'll be 140mm
To get them down to 125mm travel you add a spacer internally which would lower the height of the fork by 15mm also
Have another read of the manual on setting them up and what everything does, play about a bit with what you've picked up from there and see if its any better?
Posted : 10/05/2009 2:06 pm
