hi chaps,
I just reveived my new bike fitted with a reverb stealt.
I installed it on the bike but when i push the lever down, nothing happens...
When I push the lever, and pull up on the saddle it goes up but i springs back down pretty violent.
what could be wrong?
how do I fix this?
thanks
Do not do that pulling up again!!!
If you got it fyom lbs, take it back, if from a website, give it a bleed.
Also, check that you haven't kinked the remote hose (although the lever probably wouldn't move in that case...)
As above, bleed etc plus check PSI (on top, under saddle) mine was doing similar and after topping it up to recommended PSI (written on cap) all was well.
How do I have to adjust the pressure?
there is this knob that says "250 psi"
do I have to untread this and than there should be a valve?
thanks
Keep turning that knob until it says 300....
hey nobeer - you aren't allowed to post on these anymore, remember ... ๐
[url= http://singletrackworld.com/forum/topic/should-we-have-a-sub-forum-for-reverb-posts ]reverb posts[/url]
I'm still chuckling at someone reviewing a fox transfer after just one ride!
^^^^ ๐ now now, it was an update on the decision to buy, not a review. That will follow, maybe once it breaks... ๐
(and anyway, it was Cathkin, so probably doesn't even count as a ride....)
You'll get a ride at Cathkin no probs.....
๐ 8)
