RS Revelation dampe...
[Closed] RS Revelation damper spares
When i turn the rebound knob of my RS Revelation fork there is no clicking sound and has no effect on the damping. Ive had a long allen key up inside the damper shaft to check it wasnt the rebound knob that was worn but no joy.
Does anyone know where I can source Rockshox part number 11.4018.025.003 ???
I have tried TF Tuned, and I'm all googled out, the internet does not want to sell me one 🙁 .
Just bought a Pike so doing this as a repair to sell on, in perfect working order.
Cheers!
Posted : 15/02/2017 10:56 pm
Nil Stock at Zyrofisher and no due date.
Also try R8025003
26" fork?
Posted : 15/02/2017 11:57 pm
Planet X got any?
Posted : 16/02/2017 12:57 am
The click is just a ball bearing, spring and detent. The its either full of muck or the spring has rusted.
The no damping adjustment thing could be from a number of causes. You ought to have it apparently to know before you start spending on things you might not need.
Posted : 16/02/2017 10:14 am
You probably don't need an exact match part, there's lots of intercompatibility. TF were pretty helpful with this for me- I blew up a blackbox rev damper and it was basically uneconomic to replace it, so they found me a standard moco damper from a dead fork and swapped it in for me, they barely charged.
Posted : 16/02/2017 10:18 am
Have you had the thing apart? Could just need a full strip and service with new seals and oil. Which would be a cheaper option all round.
Posted : 16/02/2017 10:19 am
mountainbike.net and gabelprofi.de are always good for RS parts if you can't find it elsewhere. But yeah, I'd strip it and have a look first.
Posted : 16/02/2017 11:46 am
Thanks for the direction guys.
Yes I had the fork apart because the damper seals blew up and let the damper oil into the lowers, meaning the forks were hydro-locking at 40mm of 140mm travel (the non clicking damper shaft issue was prior to this though).
If I could find a cross section of the damper shaft I would have a good idea of how to fix the 'rusty' or 'stuck' ball bearing, I think I will blather penetrant oil inside the damper shaft to free the mechanism up (thanks Scienceofficer).
In the meantime I will check the part codes of other forks in the RS spares catalog to see if something matches, or if a similar fork has cheap and readily available spares.
My brand new Solo RCT3 Pike arrives on Monday anyway, got them for a steal at £570.
Posted : 16/02/2017 12:11 pm
That's the Compression damper. Rebound damper is on the shaft, isn't it?
Posted : 16/02/2017 12:12 pm
yes the rebound is on the shaft, I stripped the fork down because the seals in the upper stanchions of the damper side blew.
Posted : 16/02/2017 12:16 pm
The damper you have will be non user serviceable. The ends are crimped onto it preventing any maintinance.
Posted : 16/02/2017 6:27 pm
