Does anyone know where I can get my hands on a 2012 revelation 29er fork. Just spoke with the guys at T.F.Tuned who say that I would be able to alter the travel between 100 & 120 on this fork which is what I need at the moment. The new 2013 Rockshox range cant do this due to the new single air port design. I've carried out a brief search but nothing comes up...yet.
Anyone care to point me in the right direction?
Is the 2013 reba no good?
in the 2013 26" flavour you can stil change the travel, but you need to replace the whole air spring with a shorter one. Loco on here will know more.
I got a 29" 15mm Reba from Merlin for abot £350.....you need more travel than that? Lovely fork.
Revs can be reduced to 100mm with new air assembly, although they're not available in the UK yet (the air assms.)
We have the 2013 Rev. RCT3 29ers in stock too.
From what I understand, the new 2013 29er rebas / revs etc wont do travel adjust due to the single port design....something to do with a small groove in the stanchion that allows the negative air chamber to equalise. However the 2012 Rev's can be adjusted from 100mm upwards. I currently run a set of 2012 dual port 29er rebas but their travel is limited to between 80 & 100mm.
I got mine from Germany, you could try Bike24?
There is a Sid 29" 120mm fork for 2013 too if you fancy something lighter.
Good suggestion, I'll maybe give them a go....again with the 2013 SID's because of the single port design they cant be dropped but are fixed at 120mm. In short....I think I'm looking for something that doesn't exist!
100 - 120 adjustable travel
Taper or straight steerer
29er
15mm maxle
[url= http://www.probikeshop.com/rockshox-revelation-rct3-fork-29-dual-air-140mm-20mm-axle-tapered-white-2012/76242.html ]Try here[/url]
