RS Rev Dual Air Tea...
[Closed] RS Rev Dual Air Team....Full Travel ?
Anyone else struggle to get full travel ?
I serviced the lowers, put in 13ml of fork oil in each leg for lube. Is that too much restricting full travel ?
TIA..
Posted : 04/03/2011 5:32 pm
Had the problem twice. First time I found the damper piston would not push all the way in so replaced the damper oil. I thought 5ml was not enough and also couldn't get full travel.
Posted : 04/03/2011 10:45 pm
I've got some new 150mm RLTs and they give all their travel very readily if needed, a lot more so than a few years ago, and easier than any other air fork I've ever used. ๐Ÿ™‚
Posted : 04/03/2011 11:10 pm
PP - these are 2010's.
stripped, cleaned, lubed with 13ml of 7.5wt fork oil in each leg.
i'm assuming 13ml in each leg is affecting full travel being achievable ?
Posted : 05/03/2011 8:19 am
Have you tryed removing all the air from both chambers and compressing the fork,this will check that full travel is acheivable.
13ml is ok,think its 15ml max.
Posted : 05/03/2011 8:34 am
5ml is max for 2010
[url= http://www.sram.com/_media/pdf/rockshox/dealers/TM_MY10.pdf ]RS Tech Manual 2010[/url]
Posted : 05/03/2011 11:43 pm
ok - will strip out and relube at 5ml
Posted : 06/03/2011 8:02 pm
unreal as TFTuned told me i needed 15ml in each leg FFS ! ? !
Posted : 06/03/2011 8:05 pm
I've got 10ml in mine and still get full travel.
Posted : 06/03/2011 8:06 pm
10ml in both legs ?
Posted : 06/03/2011 8:08 pm
Aye. I couldn't find the details online so just guessed ๐Ÿ˜† But it seems to work fine.
Posted : 06/03/2011 8:18 pm
furry muff - i'll drain and relube with 5ml tomorrow night......
Posted : 06/03/2011 8:20 pm
My schoolboy arithmetic may be iffy,but for a 32mm stanchion,the depth of 15ml of oil is negligible,i.e. 0.02mm,am I missing something?
Ian
Posted : 06/03/2011 8:26 pm
ian - have you allowed for the stanchion interference and damper rods ?
Posted : 06/03/2011 8:28 pm
Oh just for clarity, 10ml [i]per[/i] leg is what's in mine.
Posted : 06/03/2011 8:44 pm
As long as you can fully compress the fork when both air chambers are empty,It will make very little difference,If any at all.
Posted : 06/03/2011 8:55 pm
