RS Recon travel cha...
[Closed] RS Recon travel change.
Can the travel on recon gold to 29er forks be altered from 100mm to 120mm?
Posted : 08/01/2016 7:53 pm
I'm pretty sure you just remove the two spacers above the top out bumper.
Spec on the SRAM website does state:
120mm travel requires 15mm Maxle and tapered steerer only
Posted : 08/01/2016 9:50 pm
Thanks for that. The forks have 100mm travel and although the head tube is tapered I'd need to check whether the forks themselves are
Posted : 08/01/2016 10:56 pm
I've got a set of xc32 solo air on my hardtail. Just changed them from 100 to 120mm travel by removing the spacers. It is a straight steerer QR fork. Pretty darn sure your recon will convert to 120mm.
Search for the "Solo Air Service Manual" on the rockshox website. It covers the Sektor/Recon/XC32 and shows u how to change the travel.
Posted : 09/01/2016 12:52 pm
Cheers pembo6
Posted : 09/01/2016 5:03 pm
