RS rebound adapter ...
[Closed] RS rebound adapter grub screw thingey
Following a 'good idea' I had on the trail I have lost the grub screw that holds my rebound adjuster in on my 2015 Pikes
Just the grub screw, the bit the allen key is in here:
Grub
I could just buy the whole adjuster from SRAM (£20) but all I need is the screw.
Anyone had any luck getting hold of one (not 50) online?
Apparently it's an "M3 .50 Pitch set screw"
Ta
Posted : 03/01/2019 9:12 pm
Send me your address by PM and I will send you one.
Posted : 03/01/2019 11:06 pm
Have a look on eBay. You could pick up a few, probably in stainless for a couple if quid. Also, check the threads as that might be the read on the set screw came out. I've seen a few with weak threads in the adjuster. I ended up helicoiling mine.
Posted : 03/01/2019 11:13 pm
Hmm - I need some spares of these, anyone a link to the correct ones
Had a quick search on eBay, m3 x 5 mm, is that right..?
Posted : 05/01/2019 8:23 pm
