Hi,
Seen a 100mm pair for sale at a good price, only thing is I really wanted 120mm ๐
Does anyone know [u]for sure[/u] if there is a spacer in this model that can be removed to do this?
Cheers.
Some OEM ones can't be upped. So without taking them apart, you won't know [u]for sure[/u].
Edit - if it's [url= http://www.on-one.co.uk/i/q/FORSRERL/rockshox_reba_rl_dual_air_100mm_fork_with_poplock__26_inch ]this[/url] one, then the "max travel: 100mm" bit would lead me to believe you'll only get 100mm out of them...
All Rebas come with the Travel Adjust Spacers inside; pull 'em apart, pop the spacers out, hey presto extra travel. ๐
Really? Just that I've got two OEM pairs, and upped the travel in both, by removing the spacers...
I had a feeling some of the newer ones cant be increased. I have some 2010 ones at 100mm and I think I read it on singletrack at some point try a search ?
Me to (thankfully).
I said "[b]some[/b]" OEM ones. Not "all". A quick search for posts on here will bring up plenty of examples where people couldn't increase travel.
I was looking at [url= http://www.wiggle.co.uk/rockshox-reba-rl-100mm-suspension-fork-2011/ ]these[/url]. No mention of 100mm max?
I've done it to two sets of them, both OEM.
I'd say the 100mm-only ones are a rare exception, if they exist at all.
As far as I knew, all Reba's can have the travel adjusted, to either 115 or 120, depending on the age, later ones to 120.
What do these spacers look like? Bought a pair of Reba'a a few months ago from On One and there were 2 black plastic blocks about 1cm or so tall inside the box.
I have a set of 100mm only ones, came off a bnoardman I think, only found out when I went to up the travel after agreeing to sell them.
anyone want a set of 100mm rebas?
Thanks for the offer [b]sssimon[/b] but I've taken the plunge anyway. ๐ฏ
I'm on an Anthem with 100mm Marzocchis so at the very worst I'll have to continue at that on Rebas. Merry Xmas to me ๐ .
My 29er Rebas can't be extended to 115mm, I have extended a pair of 26" OEM Rebas in the past.
If you look at the photo in the link, the travel increments on the stanchion dont show the 100-115mm range, so I would say no.
how much do you want sssimon?
pimm me and i will get back to you after work
milesey if you take the photo you posted, if the travel was reduced to 100mm you would still be able to see the graduations for the 120mm travel, but its just an uneducated guess.
fair point ๐ณ
