RS Pikes 426 Air U ...
[Closed] RS Pikes 426 Air U turns... 2008 views?
Hi all,
I maybe buying a set of these forks - maxle / new moco cartride so the poplock actually works...
Slight issue is that they seem to top out a bit / clunk whatever travel setting you are on - any ideas?
paul
Posted : 21/02/2012 1:25 am
Is it a little click type clunk when it hits the bottom of the travel?
Mine do the same sometimes. usually I have a quick fuss with different travel adjust, go up a couple turns pump a few times, go down, etc. then it kind of disappears.
Give it quick oil service?
The seals seem to wear and make a pike a bit noodly, which can cause it to not line up appropriately.
Posted : 21/02/2012 7:48 am
