Rs Maxle
[Closed] Rs Maxle
Ok, so perhaps I just don't get it, but why is tightening the Maxle on my Rs pikes such a PITA? I mean tightening is Ok, but getting the lever to close in an upright or horizontal position, yeah right! Checked the videos and get what I'm supposed to do but taking it in an out to adjust is also a PITA
And after overtightening today I've managed to destroy a set of bearings in my wheels?
Love the forks, but so much more of a yeah you guessed it PITA over my old Fox 36s
Educate me please!
Posted : 21/05/2014 8:48 pm
No you haven't.
You set it the first time you get it, and it sits in the same position thereafter, take the time to set it properly.
Posted : 21/05/2014 9:20 pm
Just look at how out it is.
Ie 90 degrees from straight when tight, then take it off then use the numbers to rotate 90 degrees and voilà.
Posted : 21/05/2014 9:22 pm
The only way you could destroy the bearings with the maxle is either if the wheel's assembled wrong or you managed to crush steel.
Posted : 21/05/2014 10:16 pm
Im not really sure what you mean by "getting it to tighten in an uoright or horizontal position"
I use the notch to get it tight and then flip it closed in the position i want it. You can use the rebound adjuster hex key to set the tension (ie how much it clamps shut when you close the lever down).
*Edit i have revs not pikes so sorry if thats completely useless
Posted : 22/05/2014 12:26 am
