RS Dual Position fo...
[Closed] RS Dual Position forks...
...when it says Dual position 120-150mm, does that mean:
A. Either 120 or 150mm
or
B. Anywhere between 120 - 150mm ?
I'm making a firm stab at A, but want to be sure.
And if thats right, what happened to U-Turn? (Maybe the reason I'm asking because mine are gubbed due to not keeping air in one chamber....?)
Posted : 13/04/2014 7:31 pm
Answer A. Don't know about u turn
Good forks btw
Posted : 13/04/2014 7:34 pm
Bottom line is u-turn was abandoned because apparently turning a dial is too hard, people would rather have a push-button fix even if it means the forks aren't as good (dual position is fine if you just want a climbing mode, u-turn was a genuinely travel adjustable fork)
Posted : 13/04/2014 7:39 pm
A
Dual position is good for the climbs but the bike/forks feel super weird if I try and ride anything other than uphill at 120mm.
Posted : 13/04/2014 7:43 pm
This is disappointing, but thank you for the answers.
Posted : 13/04/2014 9:12 pm
 Rich
As an aside, your u-turn forks may well only need a service or new o-ring.
Posted : 13/04/2014 10:58 pm
