Rounded off Chainri...
[Closed] Rounded off Chainring bolt - Best way to remove?
Was trying to remove the big chainring last night as a tooth is broken but inadvertendly rounded of one of the bolts and its stuck! Any ideas on the best way to remove the bolt? It's a shimano XT one. Managed to remove the other 3.
Posted : 06/07/2009 7:48 am
drill i out
you could hammer an appropriate sized torx bit into it.
Posted : 06/07/2009 7:49 am
Drill, you might need to restrain the other side somehow whilst drilling (big screwdriver or the proper tool).
Will drill easily as it's aluminium.
Posted : 06/07/2009 7:58 am
Cheers for tips, will try drilling the bolt out tonight.
Posted : 06/07/2009 10:40 am
I did this and ended up with a little set of special drill bits that had a thread running the wrong way, so basically you drilled the appropriate sized bit into the rounded off hole, it gripped and then spun the bolt out easy as pie. I forget what their called, but any handyman shop should have them.
Posted : 06/07/2009 11:00 am
drilling would no doubt work but you could also try using a screwdriver on the rear of the chainring bolt. Don't forget that this has a slotted bit on it as per the picture below (which features a Torq bolt but it's the first pic i found).
Put a suitable sized screwdriver in and turn it round to loosen off the bolt from the rear.
Of course, it may just spin but if its been in there a while there will be enough dirt and gunk in there to give resistance so that it loosens off.
Posted : 06/07/2009 11:28 am
I had a similar problem - cured by applying heat to the bolt and turning as it cooled.
Posted : 06/07/2009 12:05 pm
big rings wirk fine with broken teeth.
Posted : 06/07/2009 12:14 pm
