Rounded Crank Bolt?
[Closed] Rounded Crank Bolt?
Any suggestions for removing a rounded 8mm allen bolt?
Head is recessed into crank arm so can't grip it with anything
Posted : 15/08/2011 5:35 pm
You could try something like [url= http://www.boa-uk.com/extractor/extractorhome.html ]THIS[/url]. I failed to remove a bolt from a set of middleburn's,see picture, the other week and had to hacksaw through them.
Posted : 15/08/2011 5:48 pm
1.Hammer a star drive into it.
2.Easy out.
3.Hardened drill bit.
Posted : 15/08/2011 5:50 pm
Drill it out?
lipseal hopefully it won't come to that!
Posted : 15/08/2011 6:32 pm
I've resorted to tack-welding a cheap allen key in the bolt head using a mig welder when all else has failed, any decent garage could do it in a matter of minutes if they're not busy.
Posted : 15/08/2011 8:31 pm
Fail.
Tried drilling bolt out but unfortunately my drill only goes up to 13mm which is not sufficient, so i've went straight through and no joy.
Other than getting a bigger drill are there any other suggestions?
Posted : 21/08/2011 12:30 pm
