Rotors - Compatibil...
[Closed] Rotors - Compatibility Question
Are they all the same thickness? For example will a pair of Deore 160mm rotors work with Hayes 9 calipers?
Posted : 18/02/2012 2:20 pm
Funny you should ask...I was SAD enough to measure rotor thickness last night with some digital calipers:
Avid - 1.80
Formula - 1.75
Alligator - 1.74
didnt have a shimano rotor about but it'll be in same ballpark.
HTH
Posted : 18/02/2012 2:31 pm
As long as the diameter is right they will work.Thickness doesn't really matter(unless it's silly thick,which I doubt),think what happens when the pads start to wear down.....
Posted : 18/02/2012 2:43 pm
When you say thickness, do you mean the depth of the braking track?
Posted : 18/02/2012 3:40 pm
Fenred, not sad, more of a public service.
onza, I have no idea what you are on about?
Posted : 18/02/2012 3:44 pm
If you were to look at a hope m4 rotor and a hope c2 rotor, you could have both in 185mm diameter. The rotor would be 2mm thick. However, due to the difference in piston and pad size, one would have a deep braking track, about 22mm, the other would be shallower at around 14mm. Judging from your response though, it doesn't seem as though that's what you were asking, sorry.
Posted : 18/02/2012 3:53 pm
No worries and NEVER apologise for offering advice.
Posted : 18/02/2012 4:00 pm
