Rotor UBB 4630 (to ...
[Closed] Rotor UBB 4630 (to BBRight)
 Haze
Just looking at one of these for next time I change bearings, has anyone fitted one?
http://www.saddleback.co.uk/news/rotor-launches-new-ubb4630-bottom-bracket
As they screw together I'm thinking there may be a specific tool to do this rather than the usual press fit method.
Posted : 08/04/2017 11:49 am
There's a few that screw together now. I've not seen that one before. But if you're bbright then the WheelsMFG one will work also. I've got one I haven't fitted yet, all I needs in the way of tools is a GPX bottom bracket wrench for about £10.
Posted : 08/04/2017 1:47 pm
 Haze
Still use Loctite and activator?
Posted : 08/04/2017 4:19 pm
Not for the WheelsMFG one - just PTFE grease for a carbon frame.
Posted : 08/04/2017 4:33 pm
 Haze
Hmm, the BBRight bearings sit inboard of the frame, with only the flange of the cup on the outside.
So struggling to see how you can get a tool on it to screw it in.
Posted : 08/04/2017 4:45 pm
The flange has notches in it that correspond to the teeth on the GPX bottom bracket tool
Posted : 08/04/2017 4:53 pm
 Haze
Ah ok, makes sense looking at it again.
Posted : 08/04/2017 4:59 pm
