Want to put bigger rotors on my old black and gold mono mini's. At the moment I have 180mm front and 160mm rear both IS mount
So I buy 2 of these http://www.chainreactioncycles.com/Models.aspx?ModelID=13736 then move the 180 rotor to the rear 160+20=180 ok?
But what rotor do I buy for the front? 180+20=200 and all the rotors
seem to be 203mm?
Help please
Sizing is nominal anyway.. 203 should be fine. You can always phone hope to confirm.
At worst you'll have to space out the mount. A couple of points raise themselves though: Do you really need a 180mm rotor out back? Are the seat/chain stays strong enough to cope?
[i]Do you really need a 180mm rotor out back? [/i]
Dont know. Am doing the Passport Du Soleil and am worried about overheating my brakes.
[i]Are the seat/chain stays strong enough to cope?[/i]
Bike is an old Orange 5. ?
Find the brakes plenty strong enough (in the dry, crap when wet)
[i]Find the brakes plenty strong enough (in the dry, crap when wet) [/i]
Might just need sintered pads?
Are you "generously" proportioned? Unless you're a larger gent then generally for the PDS I'd reckon your sizes will be fine, just replace the fluid before you go.
[i]Are you "generously" proportioned? [/i]
Its not my fault "Over-active-knife-and-fork"
14 stone
14 stone? I'd say you'd be fine on the rotors you've got...
