Rotor road crank. 0...
Rotor road crank. 0.5mm spacer?
Anyone using Aldu or vegast cranks? I’m fitting some aldu 30mm jobs to replace some split duraace (!) I have the axle and arms. My frame is 68mm bsa threaded. Looking at the below chart it’s saying two 0.5mm spares are needed. Can’t figure out if they are the rotor specific spindle spacers or generic 0.5mm spacers for the cups?
I don’t have either in the garage - thought the thinnest cup spacers were 1mm anyway?
Always had 24mm Shimano road stuff! Any help deciphering the below would be much appreciated. Many thanks in advance!
Posted : 11/06/2022 1:44 pm
Probably doesn't help much but, when I got my Rotor power meter (also 30mm) it came with a box of spacers, including a 0.5mm one. I'd say they look like generic 30mm internal diameter spacers.
No fancy cutaways or ridges etc, so I guess if you can find one, and spacer will suffice.
Posted : 11/06/2022 5:52 pm
Thanks Twonks. Going to see if I get any play without any. Speak to rotor Uk on Monday and try and bottom it out.
Posted : 11/06/2022 7:59 pm
