Rotor Bolts ?
[Closed] Rotor Bolts ?
[#3309334]
Putting my old disc rotors on a new wheel.Do I use some sort of thread locking compound on the bolts ?
Thanks.
Posted : 02/11/2011 6:48 pm
Used locking compound years ago but now I just grease them. That way they're easy to get off if you want to swap discs etc.
Posted : 02/11/2011 6:49 pm
if you've got it use it if not don't bother just check your bolts after a few rides
Posted : 02/11/2011 6:50 pm
yes, although i suppose you could catch a loose disk before it falls off.
I use the triangular Shimano torx bolts with the paired alloy locktabs where possible, and a smear of high-temperature copper grease with the bolts.
That way it is very secure and you can get them off later.
Tried stainless bolts, with/without loctite and often ended up drilling them out. Not again.
PaulD
Posted : 02/11/2011 7:21 pm
Loctite 222 on all my bolts
Posted : 02/11/2011 8:26 pm
