Rotor 3D Crank Spid...
[Closed] Rotor 3D Crank Spider tool 24mm axel version
Hi All,
does anyone have a Rotor 3D Crank Spider tool I can buy or borrow? I'm based in Bath and none of the bike shops here have one. Basically I've got an annoying creak coming from the cranks and I've checked all the other likely suspects. Any help would be very much appreciated! The tool needs to be the older version for 24mm axe with 10 teeth
Many thanks,
John
Posted : 29/05/2021 11:40 pm
It's easier to send to Velotech Services than try and find the tool in my experience.
Posted : 30/05/2021 5:53 pm
I have one John, that you can borrow. Just email me on reggiegasket [at] yahoodotcodotuk
The spider on Rotor cranks can work loose, so you need to nip it up (with loctite) otherwise it'll wear the crank and spider.
Posted : 30/05/2021 6:08 pm
Thanks schmiken, I think that will cost more then I'd like to spend so I'll try and borrow Reggie's tool. How much does that cost out of interest?
Posted : 31/05/2021 10:32 pm
Thanks Reggie! have just emailed you. Still interested in buying one if anyone has a spare?
Posted : 31/05/2021 10:34 pm
 Haze
Think Velotech were about £80 to swap the spider over.
You can buy a tool from Power2Max for about €30
Posted : 01/06/2021 1:53 pm
Thanks Haze!
Posted : 02/06/2021 11:06 am
Hi Reggie, I've sent a couple of emails and also a direct message through the forum but not sure if they are reaching you? Hope everything's okay. All the best, John
Posted : 05/06/2021 10:09 am
