Rockshox Yari- how ...
[Closed] Rockshox Yari- how many tokens
8 Users
Discovered today that my rockshix Yari has 4 tokens installed. It’s 120mm. Too many? Always felt ok to me but bike shop recommended removing a couple.
Posted : 16/05/2019 11:44 pm
 poah
if it feels ok to you why remove them?
Posted : 17/05/2019 3:43 am
If you’re using most of the travel and you aren’t finding it ramps up too hard at the end then don’t change it.
If you find the fork spikes hard on big / fast hits and isn’t using near full travel then maybe have a play about with the fork.
Don’t change something you’re happy with just because someone says you should. I think the shorter the travel on the Yari the more tokens it ships with because if you run it too linear it’ll blow through all the travel too quickly.
Posted : 17/05/2019 6:15 am
4 is the correct number to adjust the airspring to 120. Whether you want more or less as said would be a personal preference.
Posted : 17/05/2019 7:08 am
I took all the tokens out of my Pike (as did Will on one of his recent reviews) and much prefer it. But we're not you.
Posted : 17/05/2019 7:35 am
My 120 came with 3 in an another two in packet.
I now run one - it just ramped so quickly with more, at speed it was really noticeable and never got full travel.
I'm now up a few psi (less sensitive on small stuff) but I do get full travel and it feels better at speed.
I'm still prefer my old Fox F120 though, that felt more supple to start with and damping felt more controlled
Posted : 17/05/2019 7:37 am
i have a 130mm travel one on my Bird, I reduced to 1 token to get full travel with the correct sag for my body weight, which is about 12.5 stone.
Posted : 17/05/2019 8:10 am
How heavy are you and how hard do you ride?
Is it fitted to a Hardtail or Full Suspension bike?
Posted : 17/05/2019 10:48 am
You can't compare tokens except in the same forks really. Pikes/Revs will run different token numbers for the same travel, and then a 2017 or earlier fork will behave differently to a 2018, and then 2019+ is different again. So the only correct answer is to experiment. Most people find a happy place +-1 token from stock in my experience though.
Posted : 17/05/2019 11:14 am
Rode it this morning with the two remaining tokens. Probably wouldn't have known if it was a blind test tbh. Maybe a little firmer at the start of the travel now and definitely a bit more travel used than previously, judging by the dust marks on the stanchions.
It's on a plus wheeled HT. Which in itself may iron a bit of the chatter out. I tend not to jump on this bike at all, other than a few drops on the local trails of 1-2 feet.
I'm about 95kg kitted up.
Posted : 17/05/2019 12:41 pm
