Hi All,
http://www.youtube.com/v/kZa4WUDUG7Q
Why is my new vivid air doing this... It doesn't appear to be losing pressure, if it is I can't tell from the 10psi you lose removing the pump... Loses all it's travel and takes forever to return with a quick ramp at the end, set up in SRAM recommended 6,3,3
Any help would be greatly appreciated.
Cheers ๐
Posted : 09/02/2014 11:17 am
have you tried a different shock pump? what pressure are you putting in?
Posted : 09/02/2014 11:28 am
ive gone from 150 up to 220psi and same effect... no not tried a different shock pump... how would that make a difference?
cheers
Posted : 09/02/2014 12:54 pm
That looks like a seal not sealing!
Posted : 09/02/2014 1:01 pm
the pump might have issues but if not, there's a major sealing problem in the shock.
Posted : 09/02/2014 1:08 pm
Send it back as that is just wrong... ๐
Posted : 09/02/2014 2:49 pm
