Rockshox Revelation...
[Closed] Rockshox Revelations U-turn Air issues
I've got a set of Rockshox Revelation U-Turn Air forks.
The travel adjuster was stuck solid.
Dropped the +/- air out of them.
Removed the top adjuster cap, one of the ballbearing had slipped off the spring.
The ballbearings seem a bit rusty.
Cleaned them up, the best i could.
Is it worth packing grease in there....?
Also what size are the bearings..?
Posted : 09/10/2011 6:11 pm
Yep, grease 'em up.
They need cleaning out once a year or so
You need at least 3 bearings on springs under the cap so it will turn smoothly
Size? Take on into your LBS and say 'Can I have some this size please!" ๐Ÿ™‚
When were the forks last serviced properly though...? Sounds like they might need doing! ๐Ÿ™‚
Posted : 09/10/2011 6:19 pm
