Rockshox Revelation...
[Closed] Rockshox Revelation U-Turn Travel Reduction?
I've got a set of 2010 Revelation Team U-Turns that have 130 t0 150mm travel and am wondering it will be possible to put a 20mm spacer I've got spare from a different set of RS forks into the fork to reduce the travel down to 110 to 130mm as this will suit by bikes frame better.
Does anybody know if this will work?
Ta
Mark
Posted : 09/10/2011 8:37 pm
 nuke
Good question...having looked at Peterpoddy's travel adjust guide, the spacer fits on the lower air shaft away from all the u-turn gubbins. Given this, I don't see why the air shaft would differ much whether all-travel version or u-turn version. I've got to service my Revs in the next week...I'll have a look unless anyone can answer before then
Posted : 09/10/2011 9:13 pm
I have 2010 u-turns set @ 140mm, I knows it possible to convert them to 150mm (seen my forks on eBay set @ 150mm). Though not sure of the details but was told on here it's definitely possible & the obviously the other way round as per your request...
Posted : 09/10/2011 9:26 pm
