RockShox recon stan...
[Closed] RockShox recon stanchion showing - how much?
As i said in a previous thread i have changed the configuration of my spacers.
They had 50mm of spacers meaning 80 mm travel, now have 30mm of spacers so 100mm travel. Weirdly they are showing 120mm of stanchion - is this correct?
Posted : 05/02/2010 11:02 pm
Dual air? Did you check the stanchion length when all spacers were in place?
Posted : 05/02/2010 11:05 pm
How much stanchion showed when set at 80mm travel? I would think it's correct, you wouldn't want full travel to bring the stanchion into or near to contact with the crown.
Posted : 05/02/2010 11:06 pm
think it was about 95mm when at 8omm travel
Posted : 05/02/2010 11:17 pm
The static height isn't important. Sit on the bike with your regular riding gear on, level the pedals, adopt your regular stood descending position and measure the sag. This is your dynamic ride height.
It's far more important than any other measurement in terms of suspension performance.
If it measures 75mm travel left, you've got a fork with 25% sag @ 100mm base setting and a supple initial to midstroke action.
Good for comfortable mostly seated XC riding.
Posted : 05/02/2010 11:26 pm
not really what i was asking but cheers anyway
Posted : 05/02/2010 11:27 pm
