rockshox recon fork...
[Closed] rockshox recon forks not well
i left my bike in the shed over winter with the pop lock left on and now i have no travel in my forks?
are the local bike shop going to spank me with a huge bill or is it a simple fix (i have no idea or time to tinker)
if it helps there 2009 recon 351 with pop lock (the 90mm - 130mm travel ajuster works fine)
cheers,
Steve...
Posted : 06/06/2011 8:36 pm
So is there no travel at all?!
It could be that all the damping oil (right hand leg) has leaked into the lower leg of the fork. This will lose travel, although I am not sure whether it will make it lose all travel or not.
Posted : 06/06/2011 8:55 pm
not even 10mm of travel, and the metal on metal sound when you drop of even a kerb isnt great either .
Posted : 06/06/2011 9:05 pm
Sounds like they had moisture in and have corroded.
If that's the case, they'll be shagged.
Posted : 06/06/2011 9:38 pm
If you are confident with what you are doing, it's probably worth stripping them down to see what's going on & if it all looks ok then rebuild with new seals.
If you aren't sure what you are doing then it might be worth ringing tft, explaining the problem & getting them sent off for some tlc.
Posted : 06/06/2011 10:08 pm
cheers for that,
not sure i like the sound of fixing them or sending them off to be honest,
ive two kids now and dont get out much, theve probably only done 100 miles since new !
looks like im off to the local bike shop again.
Posted : 07/06/2011 7:32 pm
