I noticed yesterday that between our 4 bikes, all with Rockshox forks, Ms AD and me now only have one remaining rebound adjuster, then rest most have fallen out (or been stolen).
I think this is just a 2.5mm hex, but I might get at least one replacement, despite the £20 cost.
Looks like the kit comes with 2 washers, is the blacker one just a crush washer to go under the 5mm bolt (which I would replace anyway on every other lower service), but what is the aluminium / silver one? Does that go under the 10mm air side nut? Presumably both fork legs need a washer?
Bolt, then silver washer,then black plasituc crush washer 😉
Thanks Loco, my pack of crush washers was helpfully provided by yourself!
But I think I put the washers around the wrong way yesterday and split them.
So....does another crush washer go under the 10mm nut on the air side?
cheers
the nut on air side just has a black plastic washer
Do the same crush washers fir RS & Fox?
