I checked my reba 120 uturns air pressure. it was way under for my weight (65kg without clothes etc)
the pump wouldn't put more than 50psi in either the positive or negative?
what have I done wrong?
Posted : 26/05/2013 7:00 pm
not had this specific problem - but try letting all the negative air out, then pumping the positive to your pressure of choice, then pumping up the negative
Posted : 26/05/2013 7:04 pm
tried that, its like the pressure is too high at 50psi and it wont allow anymore in.
before I tried & failed I topped up another rockshox sid fork without problem.
Posted : 26/05/2013 7:07 pm
I had something similar with mine, fault was with the pump not the fork though. Try another pump?
Posted : 26/05/2013 7:36 pm
Is it screwed on tight enough to open the valve?
Posted : 26/05/2013 8:06 pm
yeah I can get 50psi in and I can also press the button and let all the air out.
Posted : 26/05/2013 8:25 pm
