Rockshox Pike Which...
[Closed] Rockshox Pike Which Brake Mount Adaptor
Good afternoon, I've been having a mare as far as finding the correct mount to fit an XT brake calliper to my rockshox pikes. I've managed to order the wrong one off CR and Leisure Lakes near me didn't have the correct one in stock and being a numpty I've forgotten what they called it.
Could anybody help an idiot out and educate me, Its for a 180mm disk?
Thanks
Posted : 03/07/2015 4:05 pm
Kerazs reacted
I would have thought it was [url= http://www.chainreactioncycles.com/shimano-mount-adaptor-front-post-to-post/rp-prod13747 ]this[/url] post to post adapter, I believe (I may be wrong) that the mount is now 160mm ready and you simply add a little adapter booster for the extra size, so this is essentially a 20mm extension. No doubt someone will come along now to tell me I am wrong! 😉
Posted : 03/07/2015 4:24 pm
cheers, well that confirms what I was thinking last night, but needed a sanity check having already wasted a few £s on the wrong one.
Posted : 03/07/2015 5:23 pm
Yep - assuming current Pikes it's a +20mm Post to Post, also known as a 180mm Post to Post, you want.
Posted : 03/07/2015 5:34 pm
One of these... [url= http://www.chainreactioncycles.com/shimano-mount-adaptor-front-post-to-post/rp-prod13747 ]Post to post adaptor[/url]
Remember you'll need longer bolts, as the 180mm ones just act as a spacer. Some come either mounting bolts some don't.
Posted : 03/07/2015 6:08 pm
yup, that is the one. You get the longer bolts with it.
Posted : 03/07/2015 6:13 pm
awesome thanks
Posted : 03/07/2015 7:00 pm
