rockshox monarch ai...
[Closed] rockshox monarch air valve
Can anyone help?
I need a replacement air valve for my Rockshox Monarch 3.1
Does anyone know where you can get them from?
Thanks
Steve
Posted : 13/09/2014 5:03 pm
If it's just the internal bit of the valve thats gone use one out of an old schreader valved innertube, I used one on a fox float shock and it worked fine.
Posted : 13/09/2014 5:41 pm
thanks carlosg but the original valve snapped in the shock body ... it's been removed so will need the whole lot.
Thanks anyway
Posted : 13/09/2014 5:53 pm
surely if it's been removed then all you need, as carlos pointed out, is the
Schrader valve core ????
Posted : 13/09/2014 6:03 pm
no ... the whole lot spanned off so I 'm pretty sure just the schrader valve core wont do the trick as then the shock pump has nothing to screw onto ... need something like this but everyone seems to be out of stock
http://www.mountainbikebitz.com/rockshox-mountain-bike-swivel-air-valve-monarch-2010-p-19907.html
Posted : 13/09/2014 6:15 pm
Pretty much any bike shop should be able to find out if they are available/in stock from fishers (assuming they have an account),
Posted : 13/09/2014 7:31 pm
thanks wiggles ... will ask at the lbs
Posted : 13/09/2014 8:43 pm
 zedz
I had the same issue last year. I had to order the full service kit. I seem to remember I got a cheapish one somewhere. The swivel valve has a bit of a design fault as you tend to put pressure on it as you operate the pump and it starts to leak or snaps.
Try ebay etc. If I find the place I'll post it here ๐Ÿ™‚
Posted : 13/09/2014 8:54 pm
 zedz
Here you go... TFT
http://www.tftuned.com/monarch-service-kit-basic/p1312
Bit pricey though ๐Ÿ˜• I seem to remember I got one cheap from Korea, but it was over a year ago and it's still working on my son's Attack Trail, which he hammers regularly.
I'd give them a ring and see if they can just supply the valve, or send it for a service? Good luck
Posted : 13/09/2014 9:22 pm
zedz
yep ... that's the one ... pity its got the rest of the stuff with it as its a bit pricey as you say.
I'll give them a ring and see.
great stuff, thanks a lot zedz
Posted : 14/09/2014 12:21 am
Sleigh if you do find a kit I'll split it with you as I need seals.
Posted : 14/09/2014 7:30 am
zippykona ...
That sound like a good shout.
I'll do a bit more digging today and if I can't buy just the valve I'll see where is the cheapest place for the kit.
Steve
Posted : 14/09/2014 11:13 am
 LoCo
The valve assms, aren't available anymore unless you can find olds stock, the bolt is prone to shearing, seals leaking or stripping threads in shock eyelet, not a good design
Posted : 14/09/2014 12:24 pm
