RockShox Deluxe RL ...
[Closed] RockShox Deluxe RL Bushings
HI I need some help getting the right bushing parts for my RockShox Deluxe RL, 230x57.5mm. Its off a 2018 Trek remedy 7 and there is a lot of play in them.
I cant seem to find the right replacement parts online, can any please advise me?
Thanks
Posted : 23/10/2019 1:45 pm
Doesn't the deluxe have bearings?
Posted : 23/10/2019 2:09 pm
Hi chrisrobs1, The part you need is 00.4118.159.021 for the lower end of the shock.
This is 50mm offset mounting pin and the two black spacers (one longer than the other as the pin sits off-set)
You would also need a 12.7mm standard DU bush.
The mounting hardware at the top of the shock can't develop play or wear as its a Trek-specific part and is a solid press fit into the eyelet and is not a moving part
Posted : 03/11/2019 1:39 pm
