Rockshox Coil Sprin...
Rockshox Coil Spring for Fatties
I'm looking at a new bike, it comes with a coil spring. Not my first choice, but they do have some benefits.
Shock is 230 x 62.5
Using the TFT Calculator, I need a 700lbs spring... the strongest RS make is a 57.5-65mm 650.
Years ago I'd just get the 650 and wind the pre-load adjust on a bit...
Anyone think of a better solution (I'm already on a diet)
Posted : 06/11/2023 1:37 pm
Be careful, Rockshox coil springs have a slightly wider diameter than other makes and so are not always compatible.
Posted : 06/11/2023 1:46 pm
what bike is it for, have you got the correct figure, ie single pivot or vpp ?
Posted : 06/11/2023 2:06 pm
Sprindex also do a 610-700 adjustable spring that would work.
Posted : 06/11/2023 2:28 pm
 poah
preload doesn't change the overall spring rate though.
Posted : 06/11/2023 7:17 pm
