Help please.
I've got an old set of jump forks that require a new axle. They’re 20mm x 110mm qr thru axle. I’m struggling to get my head around what I can source to make them work. Anyone shed some light on my predicament, send a link to an axle or go spare part fishing in their sheds for that part that will work?
Thanks
tim
Well that didn’t work :0(
https://sportandleisure.com/products/rockshox-maxle-lite-front-thru-axle-20-x-110-mm
does it have to be QR as the boxxer has a 20 x 110
https://burgtec.co.uk/product/rockshox-boxxer-fork-axle/
What fork, maybe an Argyle?
Tftuned have this offering but not sure the DJ forks were 35mm. https://www.tftuned.com/front-maxle-lite-mtb-20x110-length-165mm-35mm40mm-chassis-2011-2016/p3449
Any use to you?
Think it was out of a Revelation.
It's 20mm whatever it came out of.
Ok, it’s a coil fork without stickers. Could be an Argyle. QR optional but my simple head says that if it looks like my photo then it’s more likely to work :0)
stu- that looks promising. Is it surplus to your requirements? DM coming if I can get the messaging thing to play nicely.
Seen as it was at the bottom of a load of old bits I think it's safe to say I no longer need it. 🙂
Fork pics.
Thanks for all the help. I had an idea that a Boxxer axle might work.
I had an original pike, same lowers as an argyle and a maxle lite from a 20mm sektor worked, there were 2 versions of the older maxle with the tapered nut on the end and one isn't compatible without adding a washer big enough to slide over the shoulder, I don't think the boxxer axle will work as it doesn't have the shoulder section for the right leg of the lowers that's fatter than 20mm.
