RockShock recon Top...
[Closed] RockShock recon Topping out??
Hi all
after going for a ride today I felt the forks where behaving "odd"
i had a bit of a further inspection on the trail and it felt as if the where "topping out" but they where no where near the top of there travel.
i had the u-turn wound down to 115mm from 130mm.
any advice would help
thanks shaun
Posted : 21/04/2011 4:15 pm
1) not enough rebound? I get his on my totems if the rebound is wound right off.
2) Or you could have lost oil through the head seal into the lower leg, to check, empty all the damping oil out by removing the top cap on the damping side and pouring into a measuring jar, it should be close to the correct filled amount. If its more than 7-10ml out then the level may have dropped below the damper by leaking past the head seal into the lower part. If this is the case then you need to replace the head seal.
Posted : 21/04/2011 4:30 pm
thanks i will have look!!
Posted : 21/04/2011 4:33 pm
Toys19 Thank you very much!! i didnt have enough rebound!!
Posted : 21/04/2011 4:52 pm
