Hi All
a friend of mine has a rockshox reverb seatpost & its return speed is very slow (even with the adjuster set to full fast). does anyone know whats required to get it back to normal? IE is it a specific problem?
actual experience appreciated, thanks!
Posted : 14/09/2012 7:37 pm
Check the pressure, that was the simple cause of mine being too slow. Been sorted for the last 5 months since topping it up
Posted : 14/09/2012 7:38 pm
Needs a bleed.
Mine did that after hose shortening, quick bleed, job done.
Kev
Posted : 14/09/2012 7:44 pm
If it makes a noise as it goes up, like a fast clicky - bleed
If not it could be the air pressue.
Posted : 14/09/2012 7:50 pm
Bleeding fixed mine too, and a mate's.
Posted : 14/09/2012 7:51 pm
cool, thanks. checked the air pressue & its at the max 250psi.
Posted : 14/09/2012 8:01 pm
Is the seat clamp too tight? Try not over tightening it see if that helps
Posted : 14/09/2012 8:08 pm
