Roadrat and 35c CX ...
[Closed] Roadrat and 35c CX tyres + Guards?
[#4599343]
Fancy some Schwalbe CX Comp tyres for my alfine-8 roadrat.
I need to run full guards too. I've currently got the SKS chromoplastic ones.
Can I get away with 700Cx35 and guards, or should I get the 700Cx30 ?
Thanks!
Posted : 27/11/2012 1:54 pm
What width are the guards?
Posted : 27/11/2012 2:11 pm
will depend on the guards...
SKS P45 guards on mine (biggest that will go in the roadrat frame without bodging) and I've used them with 700c x 38 Schwalbe snow studs. They worked fine work with decent clearance. Also used them with Kenda Small Block 8s at 700 x 35, again loads of room.
Posted : 27/11/2012 2:22 pm
Good question.
I'm not sure tbh, I think I've got the 'narrow' ones which are listed as 35mm?
Their range of guards is really confusing, blumels, chromoplastic, blah blah!
I guess I could get some new guards, but i'd prefer to keep the narrow ones I guess.
Is the consensus that with the narrow ones I can fit 30 but would be the wider ones to fit 35s?
Posted : 27/11/2012 3:57 pm
Got 700x 45 chromos and schwalbe winter marathon 35c tires on my road rat , room for wider too
Posted : 27/11/2012 3:59 pm
Be aware that once you fit guards on a RR it becomes a right pain in the arse to get the rear wheel out with the horizontal dropouts. I had a rack on mine too and in the end it was one of the 3 reasons I got rid of the bike.
Posted : 27/11/2012 4:05 pm
Not if you fit them like a thinking man
Absolutely no issues removing my wheel with mudguards still in situ, no unbolting or unclippingjust slide wheel back and drop it down.
Posted : 27/11/2012 4:09 pm
Yup, I can get the wheel out with the rack and current guards on.. although with a bigger tyre I'm sure it's harder.
Think I'll order the 30s and hope to fit them in my existing guards.
Posted : 27/11/2012 4:11 pm
