Road/Cross - 11spd ...
[Closed] Road/Cross - 11spd shimano and 11-36t cassette - will it work???
 Rik
The new 11spd long cage road mechs are rated to 32t cassettes now.
Putting together a touring adventure bike and Im running shimano 11spd 105 compact and saw this SRAM cassette 11-36t for the CX1 groupset
https://www.sram.com/sram/road/products/sram-pg-1170-11-36-cassette
As mtb mechs can handle 40t, do we think the road mechs can handle a 36t cassette???
Posted : 27/02/2015 12:51 pm
I don't know 100% but from doing some research over the past few weeks it seems it probably will (assuming longish b-tension screw and deraileur hanger), but likely only for a 1x11 setup, 2x11 at a real push, but for 3x11 you would have to swap the cage for an mtb cage to get enough chain wrap
Posted : 27/02/2015 12:55 pm
 Rik
The long cage road mechs look about the same length as the mid cage mtb mechs.
It's a shame 10 spd mtb mechs don't work with road 11spd sti - like what you can do with 9std mtb mechs and 10spd stis. That would be ace with a clutch mech.
Posted : 27/02/2015 3:57 pm
yer will work, short cage does 32t no issues depending on your mech hanger
i did old Di2 with a 11-32 XX cassette no problem, switched the jockey wheels to 10t
[URL= http://i829.photobucket.com/albums/zz211/dansipods/IMG_0390-1.jp g" target="_blank">http://i829.photobucket.com/albums/zz211/dansipods/IMG_0390-1.jp g"/> [/IMG][/URL]
Posted : 27/02/2015 4:05 pm
 Rik
Thanks but is the spacing on a mtb xx1 cassette the same as a road 11spd cassette. Plus 36t is quite a bit bigger than 32t.
That looks very cool though is that the (now redundant) k edge system?
Posted : 27/02/2015 4:10 pm
Why won't they? Different pull ratios?
Posted : 27/02/2015 4:20 pm
 Rik
Yep different pul ratio
Posted : 27/02/2015 4:35 pm
hi, i don't know how relevant this is - i built up a carbon cyclocross bike to act as an adventure racing/touring bike, and at 19 lbs weight also as my road bike.
i have a 50/34 in front and a 10 speed 11 / 36 behind, the mech is an xt. it all seems to work well with a little bit of fine tuning occasionally due to my amateur mechanics
Posted : 27/02/2015 5:27 pm
I've been looking to put a 36 on the rear too. Ive got SRAM Force and have been looking around for a slightly longer mech hanger.. I might try smaller jockey wheels too.
Posted : 27/02/2015 6:10 pm
 Rik
Any other interest? Or views
Posted : 01/03/2015 6:09 pm
 Rik
Bump for the Gnarmac lot?
Posted : 10/08/2015 8:01 pm
Bit more info on the road goatlink here...
http://www.bikerumor.com/2015/08/05/wide-range-road-on-the-cheap-lindarets-and-wtc-team-up-for-the-roadlink/#more-107318
My short cage ultegra di2 mech seems to work on a 32t cassette ok (1x11) so presume maybe the road/goatlink might just make 36t ok.
Another option is a change of cage length, noted that fibre-lyte seem to have a few carbon replacement options.
Posted : 10/08/2015 9:05 pm
 Rik
Interesting
Posted : 11/08/2015 5:59 am
