Road wheelset
[Closed] Road wheelset
[#6964997]
What wheelset for £300-400?
My current wheels are around 1550g, so around that or lighter. I weight around 70kg, so not a heavyweight, although the roads around here are terrible so they need to take a beating.
Ideally they should have cartridge bearing hubs, rather than cones.
Posted : 29/03/2015 5:09 pm
 mboy
Errr... Your current wheelset, and save yourself £300-400!
Shimano RS81 C24's are about the lightest available to fall within your budget, and you'll save yourself a massive 30g for the privilege of spending hundreds of punds!
Posted : 29/03/2015 5:39 pm
What Mboy said. There's very little difference anyway between a £300 wheel set and £500 wheel; mostly its in the hub so even if you upped your budget you still wouldn't see much benefit. Biggest improvement would be in aerodynamics but you'll need a deeper wheel and a few hundred quid more in your budget.
Posted : 29/03/2015 5:56 pm
If these are as good as, or slightly better than the Pave 28s that they have superceded, they will be superb:
http://www.superstarcomponents.com/en/dt-swiss-pave28-wheelset.htm
Strongly recommended. My son and my buddy both have the Pave 28 wheels and they feel like a £500 wheelset, though they only cost £195.
Posted : 29/03/2015 6:12 pm
I don't think you'd see any worthwhile benefits going to a £400 wheelset. If you up your budget a little, you could look at something like the Mavic Ksyrium SLS at 1395g - top quality sealed-bearing hubs with a fast pickup and a fair bit of reduction in rotating mass.
Posted : 29/03/2015 6:16 pm
Max pressure on those Superstar Pave 28s is 100psi? 😯 What are they made of, Swiss Cheese?
Posted : 29/03/2015 8:27 pm
I jumped on a pair of Zonda's when they were on offer thinking i'd be getting an upgrade from the Giant whilst that came with my Giant Defy. The reality is they are no different at all. Sure they look nicer and the rear hub/freewheel feels nicer, but weight difference is not noticeable according to the hand scales. So don't expect to notice a difference.
Posted : 29/03/2015 9:01 pm
So, it didn't occur to any of you that my current wheelset actually needs replacement? I like the wheels but the free hub is on it's way out and the rims need replacing.
They are Pro Lite Braccianos and have been brilliant: I would buy another set if they currently had a UK distro, as it is I am looking at other options.
Posted : 29/03/2015 9:06 pm
Doh!
How about Panceti SL23s on a hub of your choice with CX Rays. Built on say a 24/28 combo. Maybe avoid the Archetype as recent reports on the quality of those is very poor.
Have a look at Strada Wheels. They are excellent.
Posted : 29/03/2015 9:55 pm
Strada huh? Thanks for the suggestion, I'll have a look.
Posted : 29/03/2015 10:03 pm
 DT78
Wiggle have braccianos in stock
Posted : 29/03/2015 10:05 pm
Ooooo so they do.
Posted : 29/03/2015 10:25 pm
Pro Lite Braccianos
Hard to beat these for weight to cost ratio. If you like them, I'd just get another set.
Posted : 29/03/2015 10:33 pm
http://www.swissside.com/shop/gotthard-wheelset/
Posted : 30/03/2015 4:26 pm
