Road or MTB bottom ...
Road or MTB bottom bracket for a Sonder Camino?
What’s the difference between a road and MTB BB?
My Camino is 68mm I think but how do I know which I need? SRAM GRX says suitable for either but if I go for Uberbike I need to choose between road / MTB.
I’m running 1x SRAM GRX Rival cranks.
Posted : 15/08/2024 12:00 pm
Rival is SRAM and GRX is Shimano.
Got a link to your bike?
Posted : 15/08/2024 12:11 pm
Mostly the width.
IANAE but with bottom brackets, you've got the width of the shell, the internal diameter of the bearings/diameter of the cranks and the way that the bearings are fixed into the shell (pressfit/bsa threaded etc).
I believe that mountain bikes tend to have wider bottom bracket shells in order to fit wider tyres.
Posted : 15/08/2024 12:28 pm
Isn't it to do with axle length? I.e. MTB axles are slightly longer than road axles?
I assume the OP means Sram GXP BB as well.
Posted : 15/08/2024 12:40 pm
I'm running a BB68 BB on mine. Cranks are 24mm spindle MTB, SRAM style (actually Z-Race), and they are 100mm in length. The frame is single chainring only.
On mine, I added a single spacer to the drive side to help alignment, as the crank spindle was about half a centimetre too long for the frame, and the preload cap was binding.
From what I know, BB68 is suitable for road and MTB, the difference being how many spacers (or none) are added on each side. Road I think gets zero spacers added for installs.
Posted : 15/08/2024 2:30 pm
phil5556 and phil5556 reacted
Correction: single spacer is on the NDS.
Posted : 15/08/2024 3:13 pm
@ads678 yes, I thought that also was because of fitting a drivetrain around wider tyres?
Posted : 15/08/2024 3:25 pm
I just pulled the centre plastic big out of my old one, cleaned it up and fitted it to a new (same brand) bottom bracket.
Was a simple fix when I couldn't get the correct width bottom bracket from Chevin Cycles.
Posted : 15/08/2024 11:02 pm
Oops sorry, post nightshift ramblings…
SRAM Rival GXP! (not GRX or DUB)
Posted : 16/08/2024 12:09 am
I think I'll just get another SRAM one, it's lasted long enough and I know it fits.
I was considering going for Hope and seeing what all the fuss is about, but £100 vs £30 and I'll have to buy another tool.
Posted : 16/08/2024 2:03 am
No it's not, or at least the latest version isn't. Alpkit even sells 2x full builds, eg:
https://alpkit.com/products/sonder-camino-al-tiagra?variant=39905373159529
Fwiw, the guys at Sonder are super helpful. For a definitive answer I'd drop them a line.
Posted : 16/08/2024 8:38 am
SRAM GXP is same for road or MTB whereas Shimano has different width cups between road and MTB.  SO if getting GXP you will be fine.
Posted : 16/08/2024 9:42 am
Im pretty sure if your chainset is GXP you'll need a GXP BB due to the differing axle widths at either end.
Posted : 16/08/2024 10:01 am
Hadn't even noticed that they did a 2x, thanks for the correction.
Posted : 16/08/2024 10:06 am
