My friend has an M2C which is somewhat impractical in terms of ground clearance (and just about anything else 🙄).
Will they have any issues getting into BPW in terms of road quality?
Thanks in advance!
It's not too bad... couple of minor potholes, but whilst it's bumpy, it's OK. None of the transition points between levels are particularly harsh.
I don't know what an M2C is but as long as we're not talking 2", then it should be fine.
i wouldnt have thought so.
its a bit rough, but there isnt a massive amount of pot holes etc. And the few that do exist arent like craters.
Its no downtown Baghdad!
It’s fine in my 944t. Although it has standard ground clearance, because lowered cars are useless.
M2C = BMW M2 Competition
Nah won't have any issues. might be a bit of an uncomfy drive, but there's nothing dramatic
Great thanks.
Last year I got stuck behind a slammed RS4 at Twisted Oaks. It had the ground clearance of an overweight shrew. They managed it, but I'm sure the scuffed the shiny exhaust stick out the back
that's a LOT worse than the road into BPW.
My 116i SE was fine, so it should be okay.
There are a few holes, you can drive around them. It’s not like a farm track with a centre ridge.
The roads leading there are currently worse! An M2C won't have an issue provided he drives sensibly.
The undertray on my (lowered) caddy scrapes if I go along the centre of the road, generally fine if you keep to one side or the other.
BERLINGO!!!!
