Road gearing help
[Closed] Road gearing help
 Taff
[#4064664]
I have a '99 Giant Peloton as per below and am struggling on some of the hills in the local area which is worrying as I'm in Hampshire! Gearing on the back is 12-28 and up front I'm pretty sure it's 52-42. Colleague is convinced that I have to keep within certain ratios so providing I can still get a 7spd chain ring what's the smallest ring I can use? Ideally I would like a 38ish.
Posted : 13/06/2012 3:03 pm
38 is probably about right at a push with that BCD, 39 is the normal drop from a 52 though.
Posted : 13/06/2012 3:06 pm
yup, 38T, 39 will be easier to get and cheaper.
 Taff
39 is fine. Wicked guys. Just read I could probaly use any chain ring ie 8,9spd. Am I right?
Posted : 13/06/2012 3:36 pm
yup.
Posted : 13/06/2012 3:51 pm
Off topic but I'd look to remount your STI levers further up to have a nicer 'riding on the tops' experience.
Posted : 13/06/2012 4:01 pm
+1 m1kea good idea
Plus 39/52 would be ideal - I can (just about!) get up all the hills round here in Lancashire..
Posted : 13/06/2012 4:07 pm
 Taff
m1kea - yes I've already done that. I put them there as I didn't know what I was doing and was trying to brake while on the drops. Rarely on the drops now so have moved them up and it's much better.
Posted : 13/06/2012 4:22 pm
8)
'Compact' chainsets are all the rage these days and typically are 50/34.
It's been a very long time since I had 7 speed and I'm not sure if the width of the older chains will be too much for a more modern 9 or 10 speed chainset.
On rare occasions I run my old 8 speed Mavic trispoke and have never had problems using it with 9 or 10 speed chains. - Might be worth a new chainset and chain?
Posted : 13/06/2012 4:49 pm
has the chainring spacing on chainsets change from 7 speed days? Front mech might not work?
Posted : 13/06/2012 4:54 pm
It'll be fine if you want to go down that route. Worth considering certainly. Price of a new BB (if you're near needing one) and a 39t ring is probably the same as a Sora compact chainset.
Posted : 13/06/2012 4:56 pm
i find 50/ 36 a much nicer jump.
thats a lovely bike btw. steel?
Posted : 13/06/2012 5:06 pm
Spa Cycles in Harrogate do some very nice (and very cheap) Stronglight chainsets that might be of some use.
Decent people when sorting older drivetrains.
Posted : 13/06/2012 5:55 pm
Really? I sort of get the doe eyed adoration of a top quality steel frame, or something with a bit of heritage, lugged Colnago or something. But that's just a slightly tatty 15 year old mid-range Giant!
No offense to the OP!
Posted : 13/06/2012 6:46 pm
 poly
I recently changed the front chain ring on a 7-speed from 52/42 to 52/39 - in order to get it to shift properly the mechanic at the lbs ended up fitting it back to front. A bit of a bodge but it seems to work ok.
Posted : 13/06/2012 7:13 pm
 pdw
Only thing to watch out for is the capacity of the rear mech. 52 - 39 + 28 - 12 = 29. I think the max capacity on old rear short cage rear mechs is usually 28. It'd probably work OK, but you'll need to take care with the chain length.
Posted : 13/06/2012 8:12 pm
